소개
This guide will show you how to access the battery of the Samsung Galaxy S so that you may remove and/or replace it.
필요한 것
To remove the back case of the Samsung Galaxy S, you may need a spudger.
Identify the slit which is at the bottom edge of the phone.
Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
다른 3명이 해당 안내서를 완성하였습니다.
