주요 콘텐츠로 건너뛰기
Repairing Samsung SPH-A640 Keypad Replacement
필요한 것
  1. Repairing Samsung SPH-A640 Keypad Replacement, Back Cover: 1 단계, 이미지 1/1
    • Press and hold the “End” button until the phone powers off.
  2. Repairing Samsung SPH-A640 Keypad Replacement: 2 단계, 이미지 1/2 Repairing Samsung SPH-A640 Keypad Replacement: 2 단계, 이미지 2/2
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Repairing Samsung SPH-A640 Keypad Replacement, Keypad: 3 단계, 이미지 1/1
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. Place screws off to the side.
  4. Repairing Samsung SPH-A640 Keypad Replacement: 4 단계, 이미지 1/1
    • Using spudger, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge. Disengaging the clips near the hinge may require some force.
  5. Repairing Samsung SPH-A640 Keypad Replacement: 5 단계, 이미지 1/1
    • Using tweezers, carefully remove buttons from both sides while removing back cover. Note the positions of the buttons. They must be returned to the proper positions.
  6. Repairing Samsung SPH-A640 Keypad Replacement: 6 단계, 이미지 1/1
    • Using spudger, disconnect electrical connector near the hinge.
  7. Repairing Samsung SPH-A640 Keypad Replacement: 7 단계, 이미지 1/1
    • Using flathead screwdriver, lift motherboard away and remove from phone.
  8. Repairing Samsung SPH-A640 Keypad Replacement: 8 단계, 이미지 1/1
    • Lift, remove and replace key pad.
결론
Natasha
회원 가입일: 02/13/14
1 평판
안내서 1개 작성함
Ohio State, Team 1-2, Meza Spring 2014 Ohio State, Team 1-2, Meza Spring 2014 회원
OSU-MEZA-S14S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 7
전체 시간: 226
