이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Do your printed papers have these or similar vertical black and yellow lines?
Then this is the tutorial for you to make them disappear
다른 12명이 해당 안내서를 완성하였습니다.
댓글 7개
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
same here, if i print a blank page it has various horizontal shadows and looks dirty
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
this will laso work for the samsunc clp-310(n,w) and the clp-315(n,w)
