주요 콘텐츠로 건너뛰기
Repairing Sony Cyber-shot DSC-W290 LCD
필요한 것
  1. Repairing Sony Cyber-shot DSC-W290 LCD, Battery: 1 단계, 이미지 1/1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Repairing Sony Cyber-shot DSC-W290 LCD: 2 단계, 이미지 1/1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: 3 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: 3 단계, 이미지 2/2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Repairing Sony Cyber-shot DSC-W290 LCD: 4 단계, 이미지 1/3 Repairing Sony Cyber-shot DSC-W290 LCD: 4 단계, 이미지 2/3 Repairing Sony Cyber-shot DSC-W290 LCD: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Repairing Sony Cyber-shot DSC-W290 LCD: 5 단계, 이미지 1/3 Repairing Sony Cyber-shot DSC-W290 LCD: 5 단계, 이미지 2/3 Repairing Sony Cyber-shot DSC-W290 LCD: 5 단계, 이미지 3/3
    • Turn the camera so the right side faces you.
  6. Repairing Sony Cyber-shot DSC-W290 LCD: 6 단계, 이미지 1/1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Repairing Sony Cyber-shot DSC-W290 LCD: 7 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 7 단계, 이미지 2/2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Repairing Sony Cyber-shot DSC-W290 LCD: 8 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 8 단계, 이미지 2/2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Repairing Sony Cyber-shot DSC-W290 LCD: 9 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 9 단계, 이미지 2/2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Repairing Sony Cyber-shot DSC-W290 LCD: 10 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 10 단계, 이미지 2/2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Repairing Sony Cyber-shot DSC-W290 LCD, LCD Assembly: 11 단계, 이미지 1/1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Repairing Sony Cyber-shot DSC-W290 LCD: 12 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 12 단계, 이미지 2/2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Repairing Sony Cyber-shot DSC-W290 LCD: 13 단계, 이미지 1/2 Repairing Sony Cyber-shot DSC-W290 LCD: 13 단계, 이미지 2/2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Repairing Sony Cyber-shot DSC-W290 LCD: 14 단계, 이미지 1/1
    • Pull the LCD and its casing away from the rest of the camera.
  15. Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 15 단계, 이미지 1/3 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 15 단계, 이미지 2/3 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 15 단계, 이미지 3/3
    • Rotate the LCD and its casing so that the screen is facing you.
    • Gently pull the control panel downward, freeing it from the small metal clips.
    • Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
  16. Repairing Sony Cyber-shot DSC-W290 LCD: 16 단계, 이미지 1/3 Repairing Sony Cyber-shot DSC-W290 LCD: 16 단계, 이미지 2/3 Repairing Sony Cyber-shot DSC-W290 LCD: 16 단계, 이미지 3/3
    • Lift the LCD away from the metal casing on the right side.
    • Slide the LCD to the right and away from the metal casing.
    • Carefully pull the ribbon-wire out of the opening in the metal casing.
  17. Repairing Sony Cyber-shot DSC-W290 LCD: 17 단계, 이미지 1/1
    • The LCD is now out of the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
William Schill
회원 가입일: 10/04/10
225 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G54
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
donde puedo conseguir la pantalla? porque la mia se estrello :(
miguel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 18
전체 시간: 6,969
