소개
This guide will teach you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
필요한 것
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
다른 3명이 해당 안내서를 완성하였습니다.
