주요 콘텐츠로 건너뛰기
Repairing Sony Xperia L Volume Control Button
필요한 것
  1. Repairing Sony Xperia L Volume Control Button, Open the phone case: 1 단계, 이미지 1/3 Repairing Sony Xperia L Volume Control Button, Open the phone case: 1 단계, 이미지 2/3 Repairing Sony Xperia L Volume Control Button, Open the phone case: 1 단계, 이미지 3/3
    • The Xperia L model
    • Gently open the phone case.
    • The phone body, back case and the detached volume control button.
  2. Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: 2 단계, 이미지 1/2 Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: 2 단계, 이미지 2/2
    • Using the plastic opening tools in the iFixit kit, pull up the flattened plastic notches that will hold the volume control button in place.
    • You can see the notches on the back case and the holes in the volume control button that snap fit in them.
  3. Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: 3 단계, 이미지 1/2 Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: 3 단계, 이미지 2/2
    • Place the volume control button back in the slot.
    • Adjust the holes on the button in a way that they snap to the raised notches on the back panel.
    • Press down the raised plastic notches using the back of the plastic opening tool from the kit.
  4. Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: 4 단계, 이미지 1/3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: 4 단계, 이미지 2/3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: 4 단계, 이미지 3/3
    • The volume control button is now attached in its slot.
    • Reassemble the phone back by snapping the back case to the phone body.
    • The volume control/zoom button is good to use!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ruchita
회원 가입일: 10/22/15
73 평판
안내서 1개 작성함
PIRL Gadget Garage PIRL Gadget Garage 회원
Community
9 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,575
