주요 콘텐츠로 건너뛰기
Repairing Tent Velcro
필요한 것
  1. Repairing Tent Velcro, How to Sew a Whip Stitch: 1 단계, 이미지 1/2 Repairing Tent Velcro, How to Sew a Whip Stitch: 1 단계, 이미지 2/2
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. Repairing Tent Velcro: 2 단계, 이미지 1/3 Repairing Tent Velcro: 2 단계, 이미지 2/3 Repairing Tent Velcro: 2 단계, 이미지 3/3
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. Repairing Tent Velcro: 3 단계, 이미지 1/3 Repairing Tent Velcro: 3 단계, 이미지 2/3 Repairing Tent Velcro: 3 단계, 이미지 3/3
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. Repairing Tent Velcro: 4 단계, 이미지 1/2 Repairing Tent Velcro: 4 단계, 이미지 2/2
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. Repairing Tent Velcro: 5 단계, 이미지 1/2 Repairing Tent Velcro: 5 단계, 이미지 2/2
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. Repairing Tent Velcro: 6 단계, 이미지 1/3 Repairing Tent Velcro: 6 단계, 이미지 2/3 Repairing Tent Velcro: 6 단계, 이미지 3/3
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. Repairing Tent Velcro: 7 단계, 이미지 1/1
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,020 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 한 개
If you remembered to pack a needle, but forgot a spool of thread, and a field repair is in order: go see whether you packed any dental floss. If so, you have some hardy thread indeed, and if you bought the green minty kind, you may discover a whiff of mint now and again emanating from your repair site. I try to remember to buy the old string type of floss rather than the newer kind with flat bits, but if your needle has a big enough eye, you can thread either sort. Careful now, too thick a needle may give you threading holes larger than you want. If the repair is in a location that may leak, there are a wide variety of different things you can use to seal your sewn repair and enjoy a drier tent interior. As my preference is for canvas tents over nylon, I use beeswax, but I think a silicone spray would nicely seal a repair to nylon.
Brendan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 49
전체 시간: 5,045
