주요 콘텐츠로 건너뛰기
Repairing Tire Hole/Puncture
필요한 것
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: 1 단계, 이미지 1/1
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: 2 단계, 이미지 1/1
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: 3 단계, 이미지 1/2 Repairing Tire Hole/Puncture: 3 단계, 이미지 2/2
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: 4 단계, 이미지 1/1
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: 5 단계, 이미지 1/1
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: 6 단계, 이미지 1/3 Repairing Tire Hole/Puncture: 6 단계, 이미지 2/3 Repairing Tire Hole/Puncture: 6 단계, 이미지 3/3
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: 7 단계, 이미지 1/1
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: 8 단계, 이미지 1/1
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: 9 단계, 이미지 1/1
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: 10 단계, 이미지 1/1
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: 11 단계, 이미지 1/2 Repairing Tire Hole/Puncture: 11 단계, 이미지 2/2
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jaylynn Hoffman
회원 가입일: 10/27/15
266 평판
안내서 1개 작성함
Missouri Western, Team 1-5, Adkins Fall 2015 Missouri Western, Team 1-5, Adkins Fall 2015 회원
MWSU-ADKINS-F15S1G5
1 회원
안내서 1개 작성하였습니다
댓글 한 개
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 81
전체 시간: 5,602
