주요 콘텐츠로 건너뛰기
Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System
필요한 것
동영상 개요
  1. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System, Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 1 단계, 이미지 1/2 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System, Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 1 단계, 이미지 2/2
    • Switch-off the laptop and remove the battery.
  2. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 2 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 2 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 2 단계, 이미지 3/3
    • To remove the Keyboard you must open 7x locking clips.
    • You can use a cutter and a plastic tool.
  3. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 3 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 3 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 3 단계, 이미지 3/3
    • Remove the Keyboard.
    • Remove the HDD, RAM Memory cover.
  4. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 4 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 4 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 4 단계, 이미지 3/3
    • Remove the HDD and the DVD optical drive.
  5. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 5 단계, 이미지 1/2 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 5 단계, 이미지 2/2
    • Unscrew the screws from the upper and the bottom cases.
  6. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 6 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 6 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 6 단계, 이미지 3/3
    • With a plastic tool you can separate the bottom case from the laptop.
  7. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 7 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 7 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 7 단계, 이미지 3/3
    • Disconnect the CPU fan cable connector.
    • Now you have 4x screws on the CPU side and 2x on the fan.
  8. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 8 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 8 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 8 단계, 이미지 3/3
    • Separate the fan from the radiator.
    • Clean the radiator and the fan. Use a soft brush.
  9. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 9 단계, 이미지 1/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 9 단계, 이미지 2/3 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: 9 단계, 이미지 3/3
결론
다른 15명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,341 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,541개 작성하였습니다
댓글 8개
Very good, thank you. :-)
andymcleod - 답글
I' thank you too. :)
ZFix -
Absolutely awesome job!
Thanks a plenty.
SolaJ
SolarJ - 답글
Can't you just leave fan assembly installed and start cleaning it with brush and compressed air once you have bottom case cover off? What about just blowing air thru the grill covering the fan and not even removing the bottom case cover?
bikeboatski - 답글
I just red it and found it's not for me. But i still felt I'd instantly send $1 to the author, besides those points, which i do not care of.
So I suggest to FIXIT.COM to offer it optionally. I meean... Optinally if you want you may send $1 or more to the author.... and I would put "1" ass default. I want it tobe JUST ONE CLICK. Otherwise I leave.
Jon Pol - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 51
전체 시간: 32,087
