주요 콘텐츠로 건너뛰기
Repairing Turtle Beach PX22 Sticky Volume Wheels
필요한 것
  1. Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: 1 단계, 이미지 1/2 Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: 1 단계, 이미지 2/2
    • Remove the 4 screws from the inline amplifier using a #6 torque screwdriver head. The screws measure 1/4" long and 3/32" in diameter.
    • Open the amplifier by using the smaller plastic opening tool. Place it in the headphone jack and use leverage to pry open the plastic halves.
    • Be aware of the small plastic cylinder that braces the headphone jack.
  2. Repairing Turtle Beach PX22 Sticky Volume Wheels: 2 단계, 이미지 1/2 Repairing Turtle Beach PX22 Sticky Volume Wheels: 2 단계, 이미지 2/2
    • Remove the circuit board from the plastic housing and flip it so that you can see the scroll wheels.
    • Using a cloth dipped in isopropyl rubbing alcohol, clean the affected scroll wheels.
    • 90-100% isopropyl alcohol is preferred for cleaning.
  3. Repairing Turtle Beach PX22 Sticky Volume Wheels: 3 단계, 이미지 1/3 Repairing Turtle Beach PX22 Sticky Volume Wheels: 3 단계, 이미지 2/3 Repairing Turtle Beach PX22 Sticky Volume Wheels: 3 단계, 이미지 3/3
    • When done cleaning, place the circuit board back in the plastic housing.
    • The scroll wheels should be facing the housing with the logo and labels, and should slide onto the 4 screw holes.
    • Make sure the plastic headphone jack brace is in position.
    • Position the wire in the slot on the other side of the amplifier, it should slide down onto the housing and become fixed.
    • Close the housing with the other plastic half. It will click into place.
    • Replace the 4 screws using the #6 torque screwdriver.
결론
James de Iturrondo
회원 가입일: 03/18/15
709 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 1,441
