주요 콘텐츠로 건너뛰기
Repairing VTech Touch and Swipe Baby Phone Battery Pack
필요한 것
  1. Repairing VTech Touch and Swipe Baby Phone Battery Pack, Battery: 1 단계, 이미지 1/2 Repairing VTech Touch and Swipe Baby Phone Battery Pack, Battery: 1 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 2 단계, 이미지 1/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 2 단계, 이미지 2/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 2 단계, 이미지 3/3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 3 단계, 이미지 1/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 3 단계, 이미지 2/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 3 단계, 이미지 3/3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Repairing VTech Touch and Swipe Baby Phone Battery Pack, Repairing VTech Touch and Swipe Baby Phone Battery Pack: 4 단계, 이미지 1/2 Repairing VTech Touch and Swipe Baby Phone Battery Pack, Repairing VTech Touch and Swipe Baby Phone Battery Pack: 4 단계, 이미지 2/2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 5 단계, 이미지 1/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 5 단계, 이미지 2/3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 5 단계, 이미지 3/3
    • Remove the 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away the battery pack being careful not to tug on the wiring.
  6. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 6 단계, 이미지 1/2 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 6 단계, 이미지 2/2
    • If the batty casing solder has been disconnected you will see that the pair of red and black wires near the battery pack are no longer connected.
    • You will need to solder back on these wires to the two silver soldering plates on the battery case. The black wire should be soldered on to the plate closer next to the square plastic piece attached.
    • Make sure to correctly solder each wire as shown, because if you solder the red wire where the black wire should be your device will not function.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zack Drawdy
회원 가입일: 09/04/15
231 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 16
전체 시간: 344
