주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Vehicle Headliner
필요한 것
    1. Repairing Vehicle Headliner, Repairing Vehicle Headliner: 1 단계, 이미지 1개 중 1개
      • Prep the car for work.
      • Disconnect the negative battery terminal.
      • Removal of the right passenger seat may be necessary to help remove the headliner from the car.
      댓글 쓰기
      • Remove the trim.
      • Unbolt the sun visors, dome lamp, grab handles and any other accessories that are attached to the ceiling.
      • Remove the upper seat belt mounting loops.
      • Remove and/or pull back just enough of the side interior trim panels to gain access to the edge of the headliner. Complete removal of these panels is usually not needed.
      • Lower one side of the headliner panel and slide it over to clear the trim panels.
      • Turn the panel and remove it from the vehicle.
      댓글 쓰기
    2. Repairing Vehicle Headliner: 3 단계, 이미지 2개 중 1개 Repairing Vehicle Headliner: 3 단계, 이미지 2개 중 2개
      • Remove the old fabric from the board.
      • Place the headliner panel on a clean work table.
      • Carefully pull the old fabric material off the board. Usually the foam backing will remain stuck to the headliner board. Use a piece of the old material to rub the old foam loose from the board.
      • Vacuum the foam bits from the backing board.
      댓글 쓰기
    3. Repairing Vehicle Headliner: 4 단계, 이미지 3개 중 1개 Repairing Vehicle Headliner: 4 단계, 이미지 3개 중 2개 Repairing Vehicle Headliner: 4 단계, 이미지 3개 중 3개
      • Install new fabric:
      • If the board is damaged, repair it using aluminum tape. Any rough areas might show after the new fabric is applied.
      • Lay out the new fabric over the board. Pull 1/2 of it back over itself.
      • Spray headliner adhesive glue on 1/2 of the board and the back side of the fabric.
      • Carefully place the fabric onto the board starting from the center point and smooth it outward wit your hand as you lay it down.
      • Pull up the other 1/2of the fabric over the side you just glued down. Repeat the above steps to lay down this side of the fabric.
      댓글 쓰기
    4. Repairing Vehicle Headliner: 5 단계, 이미지 3개 중 1개 Repairing Vehicle Headliner: 5 단계, 이미지 3개 중 2개 Repairing Vehicle Headliner: 5 단계, 이미지 3개 중 3개
      • Trim up the fabric edges
      • Fold over the front & rear edges and glue them to the back side of the board about 1 inch from the edge.
      • Cut the side edges flush with the board. Also cut any access holes for the sun visors and other accessories that were previously removed.
      댓글 쓰기
    5. Repairing Vehicle Headliner: 6 단계, 이미지 3개 중 1개 Repairing Vehicle Headliner: 6 단계, 이미지 3개 중 2개 Repairing Vehicle Headliner: 6 단계, 이미지 3개 중 3개
      • Reinstall the headliner to the car:
      • Reverse the removal steps to re-install the headliner into the car.
      • Start one edge over the side trim panels and then raise the headliner into position over the other side trim panels.
      • Re-install the sun visors, dome lamp, seat belt upper loops and any other items that were previously removed
      • Lightly brush the headliner to remove marks & fingerprints.
      • If any of the trim clips break off of the interior trim panels, you can reattach them to the panel with 2-part epoxy glue.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
HemiBill
회원 가입일: 05/30/12
3,185 평판
안내서 2개를 작성함
4가이드 댓글
Excellent directions. I'd like to see a well made video of the procedure! Thanks,
Dub
bullfeather - 답글 공유
Thank you so much. I've never tried anything like this before, you've made it seem like even I can do it. I'm excited to save a cpl hundred by doing it myself!
Patti L Walton - 답글 공유
I like the steps you laid out. Its a very easy job of you have patience. Its a virtue in itself. All headliners are made different and from different material. Thank you for sharing this,
Michael Smith - 답글 공유
Excellent instructions. Thank you so much !!!
ScottHawley@2024 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 82
지난 30일: 390
전체 시간: 87,410
