소개
Having problems with your cable connection? Has replacing the cable failed to fix the problem? You may have a broken connection in your motherboard. This guide will help you repair a broken connection from the cable to the motherboard.
필요한 것
First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
(2) Phillips screws hold down covers over your inputs.
Note this screw holds down both covers where they overlap.
The bottom cover will not move until the 2 small Phillips screws are removed.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 6개
Are there pics of what needs to be done in order to solder the cable connector correctly?
how can I order the part to repair the coax connector for the Vizio 32 inch tv
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
Where can i find the nearest Service center of Vizio here in the Philippines?
I had a blank screen problem, watch how I fixed my TV https://www.youtube.com/watch?v=keBU2e2S...
Gus Calabrese - 답글
