주요 콘텐츠로 건너뛰기
Repairing a Broken Ceramic Pot
필요한 것
  1. Repairing a Broken Ceramic Pot, Repairing a Broken Ceramic Pot: 1 단계, 이미지 1/1
    • Gather all fragmented pieces of the broken pot.
    • Caution: Be careful handling broken pieces. Edges might be sharp.
  2. Repairing a Broken Ceramic Pot: 2 단계, 이미지 1/1
    • Assemble each fragment of the pot temporarily to understand where each piece goes.
  3. Repairing a Broken Ceramic Pot: 3 단계, 이미지 1/1
    • Clean the edges of the pot and its fragments with a clean cloth or paper towel.
  4. Repairing a Broken Ceramic Pot: 4 단계, 이미지 1/1
    • Apply a small amount of Waterproof Gorilla Glue to the edges of the broken pot.
    • Gorilla Glue recommends 1 dot per square inch.
    • Caution: Do not touch glue with fingers. Wear gloves for extra precaution.
  5. Repairing a Broken Ceramic Pot: 5 단계, 이미지 1/2 Repairing a Broken Ceramic Pot: 5 단계, 이미지 2/2
    • Carefully fit the fragmented piece along the glued area and hold it firmly for 10-45 seconds.
  6. Repairing a Broken Ceramic Pot: 6 단계, 이미지 1/1
    • Glue the inside of the pot for extra coverage and hold.
    • Repeat this process for other broken pieces, if any.
  7. Repairing a Broken Ceramic Pot: 7 단계, 이미지 1/1
    • Let the glue set for at least 24 hours.
결론
Repeat steps as needed until your pot is fully reassembled.
다른 한 분이 해당 안내서를 완성하였습니다.
Christina Liles
회원 가입일: 09/20/21
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 39
30일 전: 221
전체 시간: 5,733
