주요 콘텐츠로 건너뛰기
Repairing a Broken or Loose Paper Towel Hanger
필요한 것
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: 1 단계, 이미지 1/1
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: 2 단계, 이미지 1/3 Repairing a Broken or Loose Paper Towel Hanger: 2 단계, 이미지 2/3 Repairing a Broken or Loose Paper Towel Hanger: 2 단계, 이미지 3/3
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: 3 단계, 이미지 1/3 Repairing a Broken or Loose Paper Towel Hanger: 3 단계, 이미지 2/3 Repairing a Broken or Loose Paper Towel Hanger: 3 단계, 이미지 3/3
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: 4 단계, 이미지 1/3 Repairing a Broken or Loose Paper Towel Hanger: 4 단계, 이미지 2/3 Repairing a Broken or Loose Paper Towel Hanger: 4 단계, 이미지 3/3
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: 5 단계, 이미지 1/3 Repairing a Broken or Loose Paper Towel Hanger: 5 단계, 이미지 2/3 Repairing a Broken or Loose Paper Towel Hanger: 5 단계, 이미지 3/3
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
결론
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
회원 가입일: 09/08/23
121 평판
안내서 1개 작성함
York University, Team 1-21, O'Regan Fall 2023 York University, Team 1-21, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S1G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 132
