주요 콘텐츠로 건너뛰기
Repairing a Panasonic SA-HT810V with the H02/H07 error
필요한 것
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 1 단계, 이미지 3개 중 1개 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 1 단계, 이미지 3개 중 2개 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 1 단계, 이미지 3개 중 3개
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: 2 단계, 이미지 2개 중 1개 Repairing a Panasonic SA-HT810V with the H02/H07 error: 2 단계, 이미지 2개 중 2개
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: 3 단계, 이미지 1개 중 1개
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: 4 단계, 이미지 2개 중 1개 Repairing a Panasonic SA-HT810V with the H02/H07 error: 4 단계, 이미지 2개 중 2개
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Cheadle
회원 가입일: 04/15/10
161 평판
안내서 7개를 작성함
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 8개를 작성함
3가이드 댓글
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - 답글
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - 답글
Can’t get screws undone on ours… Help!
Matthew - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 28,764
