소개
This guide describes how to fix the H02/H07 error that is common with Panasonic DVD/VCR players.
필요한 것
With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
Remove the screw that is on the right side of the panel facing you.
Now rotate the device 180 degrees and remove the second screw.
Remove all screws with a phillips head screwdriver.
Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
H 02 an a Panasonic VCR can also mean tape broken and wound around capstan next to rubber roller. Ease tape out, remove tape wound around spindle, repair tape with sticky-tape. To remove tape lever up mechanism to the right of cassette, then lever up plastic holding part on the left half-way up cassette, lift door and push cassette out, minor damage may mean cassette needs help ejecting in the future.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
