주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide describes how to fix the H02/H07 error that is common with Panasonic DVD/VCR players.
부품
지정된 부품이 없습니다.
  1. With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Remove the screw that is on the right side of the panel facing you. Now rotate the device 180 degrees and remove the second screw.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Rotate the device so that the back faces you. With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Before removing top cover make sure that the back of the device is facing you.
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  5. Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Cheadle
회원 가입일: 2010년 04월 15일
137 평판
안내서 7개 작성하였습니다
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 회원
CPSU-MANESS-S10S16G5
4 회원들
안내서 7개 작성하였습니다
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - 답글
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 22
30일 전: 122
전체 시간: 24,917
