주요 콘텐츠로 건너뛰기
Repairing a Stuck Flint Wheel on a Zippo Lighter
필요한 것
  1. Repairing a Stuck Flint Wheel on a Zippo Lighter, Repairing a Stuck Flint Wheel on a Zippo Lighter: 1 단계, 이미지 1/1
    • Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
    • Be careful of the fluid that already might be in the lighter, it might leak out.
  2. Repairing a Stuck Flint Wheel on a Zippo Lighter: 2 단계, 이미지 1/1
    • Flip the lighter to face the bottom of the unit and locate the brass colored screw.
  3. Repairing a Stuck Flint Wheel on a Zippo Lighter: 3 단계, 이미지 1/3 Repairing a Stuck Flint Wheel on a Zippo Lighter: 3 단계, 이미지 2/3 Repairing a Stuck Flint Wheel on a Zippo Lighter: 3 단계, 이미지 3/3
    • Loosen the brass screw with the flat head screwdriver
    • Unscrew the rest of the brass screw using your hand.
    • Unscrew the brass screw until it comes off and the spring beneath shows but do not take the spring all the way out.
  4. Repairing a Stuck Flint Wheel on a Zippo Lighter: 4 단계, 이미지 1/1
    • Pull the brass screw and spring out about a centimeter or two to unhinge the steel rod located beneath the flint wheel so that the rod and the wheel are not touching.
    • If necessary, tap the unit to unhinge the steel rod
  5. Repairing a Stuck Flint Wheel on a Zippo Lighter: 5 단계, 이미지 1/1
    • Follow the steps backwards to reassemble the unit and check to see if the flint wheel is unstuck.
결론
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
다른 32명이 해당 안내서를 완성하였습니다.
Joseph Yoo
회원 가입일: 04/09/15
983 평판
안내서 1개 작성함
Cal Poly, Team 28-3, Green Spring 2015 Cal Poly, Team 28-3, Green Spring 2015 회원
CPSU-GREEN-S15S28G3
4 회원들
안내서 9개 작성하였습니다
댓글 29개
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
Nabiel Wahedi - 답글
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
Bret lauk -
You need to replace the flint itself in that case.
jayanthkumarak - 답글
Wonderful instructions! AND IT WORKED! Thank you.
John Heard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 23
7일 전: 243
30일 전: 1,082
전체 시간: 147,837
