주요 콘텐츠로 건너뛰기
Repairing a Wobbly Piano Bench
필요한 것
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: 1 단계, 이미지 1개 중 1개
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: 2 단계, 이미지 1개 중 1개
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: 3 단계, 이미지 3개 중 1개 Repairing a Wobbly Piano Bench: 3 단계, 이미지 3개 중 2개 Repairing a Wobbly Piano Bench: 3 단계, 이미지 3개 중 3개
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: 4 단계, 이미지 3개 중 1개 Repairing a Wobbly Piano Bench: 4 단계, 이미지 3개 중 2개 Repairing a Wobbly Piano Bench: 4 단계, 이미지 3개 중 3개
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: 5 단계, 이미지 1개 중 1개
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: 6 단계, 이미지 2개 중 1개 Repairing a Wobbly Piano Bench: 6 단계, 이미지 2개 중 2개
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: 7 단계, 이미지 2개 중 1개 Repairing a Wobbly Piano Bench: 7 단계, 이미지 2개 중 2개
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
결론
You can redo this process every 6 months to make sure your bench is always stable.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Davood Dehghani Firoozabadi
회원 가입일: 09/20/20
452 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 1,433
