주요 콘텐츠로 건너뛰기
Repairing a plastic drill bit for a toy drill
필요한 것
  1. Repairing a plastic drill bit for a toy drill, Repairing a plastic drill bit for a toy drill: 1 단계, 이미지 1개 중 1개
    • Match up the broken plastic part and check that the pieces align.
    • The plastic part was hollow and had space to insert the wood support.
  2. Repairing a plastic drill bit for a toy drill: 2 단계, 이미지 1개 중 1개
    • Tools needed:
    • - Glue (Super glue, Wood Glue or Tacky glue)
    • - A bamboo chopstick from your favorite chinese restaurant
  3. Repairing a plastic drill bit for a toy drill: 3 단계, 이미지 1개 중 1개
    • Cut the chopstick to the required size using a sharp knife.
    • Some trimming and shaving may be needed depending on the plastic part and the wooden dowel with the objective of to get a tight fit.
  4. Repairing a plastic drill bit for a toy drill: 4 단계, 이미지 1개 중 1개
    • Apply a drop of glue to the ends of the wooden dowel.
  5. Repairing a plastic drill bit for a toy drill: 5 단계, 이미지 1개 중 1개
    • Insert the wooden dowel into one part of the broken plastic part.
  6. Repairing a plastic drill bit for a toy drill: 6 단계, 이미지 2개 중 1개 Repairing a plastic drill bit for a toy drill: 6 단계, 이미지 2개 중 2개
    • Insert the other end of the wooden dowel into the other end of the plastic toy.
    • Push the ends together to get a tight and clean fit.
결론
작성자
4다른 기여자 명과 함께
claudius
회원 가입일: 12/12/10
29 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 3,601
