주요 콘텐츠로 건너뛰기
Repairing iPhone 4 dust mesh
필요한 것
  1. Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: 1 단계, 이미지 1/2 Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: 1 단계, 이미지 2/2
    • Left image shows iPhone with missing front dust mesh
    • Right image shows dust meshes on bottom
  2. Repairing iPhone 4 dust mesh: 2 단계, 이미지 1/2 Repairing iPhone 4 dust mesh: 2 단계, 이미지 2/2
    • Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
    • Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
  3. Repairing iPhone 4 dust mesh: 3 단계, 이미지 1/2 Repairing iPhone 4 dust mesh: 3 단계, 이미지 2/2
    • Fold the piece of mesh longways using the plastic tip
    • Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
    • Put piece of mesh into place using plastic tip
    • That's it - see the result on the images
결승점
다른 28명이 해당 안내서를 완성하였습니다.
aiwo
회원 가입일: 03/13/12
2,286 평판
안내서 1개 작성함
댓글 한 개
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
Rene Jeddore - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 14
전체 시간: 50,266
