이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Left image shows iPhone with missing front dust mesh
Right image shows dust meshes on bottom
Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
Fold the piece of mesh longways using the plastic tip
Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
Put piece of mesh into place using plastic tip
That's it - see the result on the images
다른 28명이 해당 안내서를 완성하였습니다.
댓글 한 개
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
