주요 콘텐츠로 건너뛰기
Repairing nose pads on eyeglasses
필요한 것
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: 1 단계, 이미지 1/2 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: 1 단계, 이미지 2/2
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: 2 단계, 이미지 1/2 Repairing nose pads on eyeglasses: 2 단계, 이미지 2/2
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: 3 단계, 이미지 1/1
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: 4 단계, 이미지 1/2 Repairing nose pads on eyeglasses: 4 단계, 이미지 2/2
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: 5 단계, 이미지 1/2 Repairing nose pads on eyeglasses: 5 단계, 이미지 2/2
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Vivi Chou
회원 가입일: 04/28/17
151 평판
안내서 1개 작성함
UC Davis, Team S3-G4, Coad Spring 2017 UC Davis, Team S3-G4, Coad Spring 2017 회원
UCD-COAD-S17S3G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 89
30일 전: 357
전체 시간: 47,304
