이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
To take apart the strap lock, take the black ball cap and turn it counterclockwise.
After you unscrew the ball cap, pull on the other side of the locking mechanism (opposite to the ball cap) to remove the spring and bar.
You should have these two parts removed from the rest of the lock mechanism.
If you do not have the spring or your spring is broken, you can get the spring described in the conclusion.
Once the spring is on, reassemble your strap lock by inserting the locking mechanism into the underside of the housing.
Then, screw back on the ball cap.
