주요 콘텐츠로 건너뛰기
Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panels: 1 단계, 이미지 1/2 Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panels: 1 단계, 이미지 2/2
    • Remove back panels by applying pressure and slide outwards. Check to see if there are batteries or if they need replacing.
  2. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panel: 2 단계, 이미지 1/2 Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Remove Back Panel: 2 단계, 이미지 2/2
    • Begin removing screws from back panel. There should be of 8 screws all together. Be sure not to lose them after removing! Also separate the outer screws and the inner screws. The screws are two different sizes so don't mix them up.
  3. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Cleaning Time: 3 단계, 이미지 1/2 Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Cleaning Time: 3 단계, 이미지 2/2
    • Carefully clean around the circuit board with cloth. Then brush the inside of the outer shell and wipe it down with the cloth as well. Be careful not to disconnect the wires. Carefully replace the circuit board and close the shell. Rescrew the screws, make sure the correct ones are entered into the correct slot.
  4. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Clean Screen!: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Spray a small amount of applejuice brand spray (screen cleaner) and use micro fiber cloth and wipe back and forth until the screen is clean.
  5. Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Ta Da!: 5 단계, 이미지 1/2 Repairing/Cleaning LeapFrog LeapPad2 Explorer IN 4 STEPS, Ta Da!: 5 단계, 이미지 2/2
    • Ta Da! Your device is now cleaned and has been checked. Try to power on, hopefully your leap pad will function correctly. If not, please contact Leap Frog Co. directly.
결론
Lauren
회원 가입일: 11/13/14
1 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 613
