주요 콘텐츠로 건너뛰기
Replace Apple Xserve 2009 Motherboard and fans
필요한 것
  1. Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: 1 단계, 이미지 2개 중 1개 Replace Apple Xserve 2009 Motherboard and fans, Xserve 2009 MLB and Fan replacement: 1 단계, 이미지 2개 중 2개
    • Notable specs:
    • Dual Xeon Nehalem CPU @ 2.26 GHz
    • No SSD
    • No Hardware RAID
  2. Replace Apple Xserve 2009 Motherboard and fans: 2 단계, 이미지 1개 중 1개
    • Pull on release lever, and pull power supply out.
  3. Replace Apple Xserve 2009 Motherboard and fans: 3 단계, 이미지 2개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 3 단계, 이미지 2개 중 2개
    • Loosen the 2 thumbscrews on the back of the xserve to release the top.
    • Slide top back, and lift top off.
  4. Replace Apple Xserve 2009 Motherboard and fans: 4 단계, 이미지 1개 중 1개
    • This step is not necessary if you are not changing the drive. It does not interfere with the rest of the procedure.
    • If the hard drives or blanks are still in the xserve, push the handle in to pop it out.
    • Pull the hard drive and blank sleds out.
  5. Replace Apple Xserve 2009 Motherboard and fans: 5 단계, 이미지 3개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 5 단계, 이미지 3개 중 2개 Replace Apple Xserve 2009 Motherboard and fans: 5 단계, 이미지 3개 중 3개
    • Slide lever lock to release the CD/DVD drive.
    • Slide CD/DVD drive back.
    • Lift drive up and unplug the SATA connector on the back.
  6. Replace Apple Xserve 2009 Motherboard and fans: 6 단계, 이미지 1개 중 1개
    • Using a #1 Phillips screwdriver, unscrew the screws on each side of PCI slot #2 on the back of the computer.
    • Once the screws are loosened, the PCI riser card should lift out of the slot.
    • Repeat for PCI slot #1
  7. Replace Apple Xserve 2009 Motherboard and fans: 7 단계, 이미지 1개 중 1개
    • Remove the RAM from all slots.
  8. Replace Apple Xserve 2009 Motherboard and fans: 8 단계, 이미지 2개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 8 단계, 이미지 2개 중 2개
    • Using a 3.0mm Hex wrench (Allen wrench), loosen the 4 screws that hold the processor and heatsink down.
    • Unplug the sensor cable.
    • Lift the heatsink and processor off the motherboard.
    • Repeat if you have the dual processor model.
  9. Replace Apple Xserve 2009 Motherboard and fans: 9 단계, 이미지 3개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 9 단계, 이미지 3개 중 2개 Replace Apple Xserve 2009 Motherboard and fans: 9 단계, 이미지 3개 중 3개
    • Using a #1 phillips screwdriver, loosen the 5 screws that hold the plastic bezel in place.
    • Remove the plastic bezel.
    • Using a #2 phillips screwdriver, loosen the 2 screws that hold the fan array in place
    • Lift the fan array out.
  10. Replace Apple Xserve 2009 Motherboard and fans: 10 단계, 이미지 2개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 10 단계, 이미지 2개 중 2개
    • Using the spudger, lift the connector on the right.
    • Carefully squeeze the connector on the left and unplug it.
    • Using the spudger, lift the CD/DVD connector by the CPU A RAM slots.
  11. Replace Apple Xserve 2009 Motherboard and fans: 11 단계, 이미지 3개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 11 단계, 이미지 3개 중 2개 Replace Apple Xserve 2009 Motherboard and fans: 11 단계, 이미지 3개 중 3개
    • Using a #2 screwdriver, loosen the 9 screws that hold the motherboard in place.
    • There are 3 rows of 3 screws each. 1 row by the back of the computer, 1 row in the middle and 1 row by the fan array. They are obvious by the black plastic spacer/retainer on them.
  12. Replace Apple Xserve 2009 Motherboard and fans: 12 단계, 이미지 1개 중 1개
    • Using a #2 screwdriver, loosen the screw on the power board.
    • Slide it up to disconnect it from the motherboard.
  13. Replace Apple Xserve 2009 Motherboard and fans: 13 단계, 이미지 2개 중 1개 Replace Apple Xserve 2009 Motherboard and fans: 13 단계, 이미지 2개 중 2개
    • Remove the 2 screws that hold the video card on.
    • Slide the card out of the socket.
  14. Replace Apple Xserve 2009 Motherboard and fans: 14 단계, 이미지 1개 중 1개
    • Lift the motherboard and slide it out ofthe connectors on the back of the computer.
    • Then tip the motherboard up and out of the computer.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tod Hallberg
회원 가입일: 07/08/14
677 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 105
전체 시간: 12,170
