주요 콘텐츠로 건너뛰기
Replace BlackBerry 7130e Speaker
필요한 것
  1. Replace BlackBerry 7130e Speaker, battery: 1 단계, 이미지 1/1
    • Turn the phone over so that the screen is facing the work surface
  2. Replace BlackBerry 7130e Speaker: 2 단계, 이미지 1/1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. Replace BlackBerry 7130e Speaker: 3 단계, 이미지 1/1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
  4. Replace BlackBerry 7130e Speaker, BlackBerry 7130e Disassembly: 4 단계, 이미지 1/1
    • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  5. Replace BlackBerry 7130e Speaker: 5 단계, 이미지 1/1
    • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  6. Replace BlackBerry 7130e Speaker: 6 단계, 이미지 1/1
    • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
    • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
  7. Replace BlackBerry 7130e Speaker: 7 단계, 이미지 1/1
    • Remove top two screws with T6 Torx screw driver, from the back of phone.
  8. Replace BlackBerry 7130e Speaker: 8 단계, 이미지 1/1
    • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  9. Replace BlackBerry 7130e Speaker: 9 단계, 이미지 1/2 Replace BlackBerry 7130e Speaker: 9 단계, 이미지 2/2
    • You should now be able to easily separate the phone into two pieces.
    • The battery prong may fall out when the separation occurs, just don't loose it!
  10. Replace BlackBerry 7130e Speaker, speaker: 10 단계, 이미지 1/1
    • Set aside the bottom part of the phone.
    • Drop out the rubber keypad from the top, so that it does not get in the way.
  11. Replace BlackBerry 7130e Speaker: 11 단계, 이미지 1/1
    • Use the plastic separator tool to apply significant pressure in a downward motion on the top of the white speaker unit.
  12. Replace BlackBerry 7130e Speaker: 12 단계, 이미지 1/1
    • The speaker unit should become loose.
    • You can now push the separating tool beneath the speaker and pop it out.
    • Once the defective unit is removed, pop your new speaker unit back into place.
결론
Sean Tiernan
회원 가입일: 01/20/10
5 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-16, Maness Winter 2010 Cal Poly, Team 3-16, Maness Winter 2010 회원
CPSU-MANESS-W10S3G16
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,186
