소개
The spur gears can wear out or be destroyed if the blender binds. The exchange is very easy.
필요한 것
The spur gears are fixed from above by a metal plate. This metal plate is inserted into a large plastic tab on both sides.
Gently push one of the two tabs outwards a little until the metal plate comes out of the slot.
Lift the metal plate complete with the controller and tensioner up and away and set it aside.
The two clamps for the stirring inserts are on top of the spur gears. Just lift them out
Work the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
