주요 콘텐츠로 건너뛰기
Replace HP Z820 GPU.
  1. Replace HP Z820 GPU., Opening the PC case: 1 단계, 이미지 2개 중 1개 Replace HP Z820 GPU., Opening the PC case: 1 단계, 이미지 2개 중 2개
    • First, pull the handle and raise the upper part of the case.
    • Make sure that you have unlocked the lock that is located close to the handle.
    • After taking the upper part off, you'll see the covers of the different pieces of the PC.
  2. Replace HP Z820 GPU., Opening the GPU compartment: 2 단계, 이미지 3개 중 1개 Replace HP Z820 GPU., Opening the GPU compartment: 2 단계, 이미지 3개 중 2개 Replace HP Z820 GPU., Opening the GPU compartment: 2 단계, 이미지 3개 중 3개
    • Raise the cover of the left lower side.
  3. Replace HP Z820 GPU., GPU with guide: 3 단계, 이미지 1개 중 1개
    • This PC has a full-sized GPU with a guide that fits the GPU in the case. That allows you to avoid physicall damages on the GPU.
    • The GPU has a guide. It's necessary to pay attention and don't forget about it while taking the GPU off.
  4. Replace HP Z820 GPU., GPU Removal, Part 1: 4 단계, 이미지 2개 중 1개 Replace HP Z820 GPU., GPU Removal, Part 1: 4 단계, 이미지 2개 중 2개
    • Disconnect the power connector from the GPU.
    • You can clip the connectors in a specifically designed place.
    • Raise the rod that maintains the PCI GPU in place.
  5. Replace HP Z820 GPU., GPU Removal, Part 2: 5 단계, 이미지 3개 중 1개 Replace HP Z820 GPU., GPU Removal, Part 2: 5 단계, 이미지 3개 중 2개 Replace HP Z820 GPU., GPU Removal, Part 2: 5 단계, 이미지 3개 중 3개
    • The first two steps must be performed simultaneously. If you release the tab, it returns to its previous position.
    • Raise the tab that maintains the GPU in its port.
    • Raise the GPU slowly from the side of the guide until the GPU partially comes out of its port.
    • Raise the GPU from its other side.
  6. Replace HP Z820 GPU., Installation using the guide: 6 단계, 이미지 3개 중 1개 Replace HP Z820 GPU., Installation using the guide: 6 단계, 이미지 3개 중 2개 Replace HP Z820 GPU., Installation using the guide: 6 단계, 이미지 3개 중 3개
    • If your GPU has no guide, you can go to the next step.
    • Introduce the new GPU at 45º from the motherboard.
    • Pay attention and avoid damaging the motherboard during the insertion.
    • Place the guide in front of the appropriate slot and push the graphics card into it, making sure it fits into its PCI slot.
    • To check that your graphics card is correctly installed, check that the tab is properly locked in place.
    • Don't forget to connect the power supply cables of the GPU if it's necessary.
  7. Replace HP Z820 GPU., Installation without guide: 7 단계, 이미지 2개 중 1개 Replace HP Z820 GPU., Installation without guide: 7 단계, 이미지 2개 중 2개
    • Insert the graphics card into the PCI bracket until it clicks into place.
    • Don't forget to connect the power supply connectors to the GPU if it's necessary.
  8. Replace HP Z820 GPU., Case's particularity: 8 단계, 이미지 2개 중 1개 Replace HP Z820 GPU., Case's particularity: 8 단계, 이미지 2개 중 2개
    • The Sapphire RX 5700XT GPU is the largest card that fits in the case without problems.
    • Maximum GPU height: 11cm.
    • As it's already explained, the case has special spots for clipping the unused power supply ports.
결론
The reinstallation stages are included in the tutorial.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Hyperion
회원 가입일: 12/13/15
2,074 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 31
전체 시간: 1,850
