주요 콘텐츠로 건너뛰기
Replace Logitech MX mechanical key
필요한 것
  1. Replace Logitech MX mechanical key, Remove keycaps: 1 단계, 이미지 2개 중 1개 Replace Logitech MX mechanical key, Remove keycaps: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Keycap Puller
    $6.95
    • Use a keycap remover tool / opening tool or your hands to remove all keycaps.
    • Make a few photos of your keybord layout to have a reference for reassembly later on.
    • If your keybord is dirty use a soft brush to clean it.
  2. Replace Logitech MX mechanical key, Unscrew 20x black screws: 2 단계, 이미지 2개 중 1개 Replace Logitech MX mechanical key, Unscrew 20x black screws: 2 단계, 이미지 2개 중 2개
    • Remove 20x black screws with a Philips size 0 screwdriver.
    • Don't loose the screws, put them in a bin or similar.
  3. Replace Logitech MX mechanical key, Open back cover: 3 단계, 이미지 3개 중 1개 Replace Logitech MX mechanical key, Open back cover: 3 단계, 이미지 3개 중 2개 Replace Logitech MX mechanical key, Open back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is held in place by small plastic tabs.
    • Flip the keyboard on its front.
    • There is a small slid between the back cover and the body. Insert a thin plastic opening pick at the top of the keyboard.
    • Use something sturdy, like a metal spudger to release the plastic tabs all around.
    • There is a cable comming from the battery and connecting the plastic cover and the keyboard front. The connecter is clipped into the plastic frame above the PCV and can be unclipped using some tweezers or spudger.
  4. Replace Logitech MX mechanical key, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 1개 Replace Logitech MX mechanical key, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 2개 Replace Logitech MX mechanical key, Remove plastic frame above PCB: 4 단계, 이미지 3개 중 3개
    • Disconnect controller from battery.
    • Disconnect ribbon cable from controller.
    • The plastic frame above the PCB is connected via screws. Unscrew 6x silver screws using a size 2 philips screwdriver.
    • Remove the black plastic frame covering the PCB.
  5. Replace Logitech MX mechanical key, (Optional) Remove screws holding PCB: 5 단계, 이미지 2개 중 1개 Replace Logitech MX mechanical key, (Optional) Remove screws holding PCB: 5 단계, 이미지 2개 중 2개
    • There are 4 capped screws (silver) fixing the PCB to the metal part of the keyboard. One hides under the ribon cable.
    • Removing the switches isn't covered by this guide.
    • The switches for this model are Kailh Choc V2 Low Profile Switches.
  6. Replace Logitech MX mechanical key, Mark the defective key: 6 단계, 이미지 2개 중 1개 Replace Logitech MX mechanical key, Mark the defective key: 6 단계, 이미지 2개 중 2개
    • To avoid confusion later, mark the defective key. In this case, the “D” key is defective and is marked with a felt-tip pen.
    • Locate and mark the back of the defective key. Each key is connected to the circuit board at three solder points. The black pin is only inserted and not connected to the circuit board.
  7. Replace Logitech MX mechanical key, Desoldering key: 7 단계, 이미지 3개 중 1개 Replace Logitech MX mechanical key, Desoldering key: 7 단계, 이미지 3개 중 2개 Replace Logitech MX mechanical key, Desoldering key: 7 단계, 이미지 3개 중 3개
    • Desolder the three solder joints on the button you marked earlier:
    • Heat the pin until all the existing solder is liquid.
    • Add some fresh solder.
    • Remove the liquid solder with a desoldering pump.
    • After desoldering, you can push the button out from the front.
  8. Replace Logitech MX mechanical key, Solder the replacement key: 8 단계, 이미지 2개 중 1개 Replace Logitech MX mechanical key, Solder the replacement key: 8 단계, 이미지 2개 중 2개
    • Insert the replacement key into the gap in the circuit board. It only fits into the gap one way.
    • Re-solder the three solder joints.
결론
To reassemble your device, follow the relevant steps in the instructions in reverse order.
Before replacing all the key caps, test the function of the new key.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
AnHeuermann
회원 가입일: 08/26/24
368 평판
안내서 2개를 작성함
3가이드 댓글
Thank you! This was very helpful. rrh
rrh - 답글
The c-key has had an intermittent problem on my Logitech MX Mechanical Wireless (tactile) and outstanding guide will give me the confidence to give repairing it a go, saving waste and money.
Thank you
Jack - 답글
Thank you ! I just swapped a damaged key with less used healthy key by following this guide. Saved me from an ongoing frustration and money.
P V - 답글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 110
지난 30일: 515
전체 시간: 3,024
