주요 콘텐츠로 건너뛰기
Replace MSI GT72 2QE Dominator Pro Wireless Card
필요한 것
  1. Replace MSI GT72 2QE Dominator Pro Wireless Card, Wireless Card: 1 단계, 이미지 1/2 Replace MSI GT72 2QE Dominator Pro Wireless Card, Wireless Card: 1 단계, 이미지 2/2
    • Remove the seven 6 mm Philips #0 screws on the bottom of the case.
  2. Replace MSI GT72 2QE Dominator Pro Wireless Card: 2 단계, 이미지 1/1
    • Gently pull from the rear of the case upwards to remove the bottom of the laptop.
  3. Replace MSI GT72 2QE Dominator Pro Wireless Card: 3 단계, 이미지 1/1
    • Remove the yellow tape from the wireless card at the center right of the board.
  4. Replace MSI GT72 2QE Dominator Pro Wireless Card: 4 단계, 이미지 1/2 Replace MSI GT72 2QE Dominator Pro Wireless Card: 4 단계, 이미지 2/2
    • Using a pair of pliers, remove both wires by pulling straight up from the wireless card.
    • Do not jerk or yank too hard as it can break off connectors.
  5. Replace MSI GT72 2QE Dominator Pro Wireless Card: 5 단계, 이미지 1/2 Replace MSI GT72 2QE Dominator Pro Wireless Card: 5 단계, 이미지 2/2
    • Remove one Philips #0 screw from the motherboard.
  6. Replace MSI GT72 2QE Dominator Pro Wireless Card: 6 단계, 이미지 1/1
    • Pull card up and out from the motherboard.
    • Do not touch gold contacts as it can damage the card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Robert Stepp
회원 가입일: 07/24/20
181 평판
안내서 1개 작성함
UW Tacoma, Team S1-G16, Cardinal Summer 2020 UW Tacoma, Team S1-G16, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G16
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 27
전체 시간: 1,069
