주요 콘텐츠로 건너뛰기
Replace Philips ceramic grinder motor and sensor
필요한 것
  1. Replace Philips ceramic grinder motor and sensor, Before assembly: 1 단계, 이미지 1개 중 1개
    • Take a photo of the mark on the large gear wheel; it should be in the same position when you reassemble it.
    • Although the motor is powered by 230 V, diodes ensure that only positive half-waves are supplied, so that the motor only rotates in one direction. Make a note of how the connection cables are plugged in. Test later to see if it is rotating in the correct direction.
    • You can test the motor with approximately 25 V DC. It should turn easily and draw approximately 120 mA. If this is not the case, check the carbon brushes on the side. Only then should you consider replacing it.
    • Insert translation here
    • Any brackets—in this case, the black rubber sleeve—must be transferred to the new part.
    • The speed sensor can only be removed from the inside. To do this, you must disconnect its plug from the main circuit board and expose the cables.
  2. Replace Philips ceramic grinder motor and sensor, Remove the motor: 2 단계, 이미지 2개 중 1개 Replace Philips ceramic grinder motor and sensor, Remove the motor: 2 단계, 이미지 2개 중 2개
    • There are four Torx T10 screws on the underside of the grinding mechanism. Remove those.
    • The screw marked in yellow must not be removed when replacing the motor.
    • The white plastic sleeve around the screw marked in yellow must be transferred to the replacement part.
    • Lift off the motor.
  3. Replace Philips ceramic grinder motor and sensor, Transferring the sensor: 3 단계, 이미지 3개 중 1개 Replace Philips ceramic grinder motor and sensor, Transferring the sensor: 3 단계, 이미지 3개 중 2개 Replace Philips ceramic grinder motor and sensor, Transferring the sensor: 3 단계, 이미지 3개 중 3개
    • The machine's electronic use the sensor to measure the number of revolutions. The sensor must be transferred to the new motor.
    • The sensor is secured on the inside with a locking tab. It can therefore only be removed from the inside.
    • Press the locking tab firmly down with a flat screwdriver.
    • Slide the sensor out, using the flat screwdriver to help if needed.
    • Transfer the sensor to the new part.
  4. Replace Philips ceramic grinder motor and sensor, Completion: 4 단계, 이미지 1개 중 1개
    • Grease the worm gear on the new motor a little; the old grease may be sufficient, but new grease is better.
    • Check that the plastic bushing is seated properly in the center opening. Screw the motor tight.
결론
Follow the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
297,872 평판
안내서 303개를 작성함
Repair is War on Entropy Repair is War on Entropy 회원
Community
32 회원들
안내서 1,570개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 110
지난 30일: 384
전체 시간: 2,435
