주요 콘텐츠로 건너뛰기
Replace defective capacitor in a power supply
필요한 것
    • ATTENTION: 230V are processed in the monitor. So take the necessary care. And a little experience with electronics and soldering should be available.
  1. Replace defective capacitor in a power supply: 2 단계, 이미지 1개 중 1개
    • The main focus here is on troubleshooting. First disconnect all plugs and then loosen the housing screws.
    • Now check whether an electrolytic capacitor has "blown up". Most electrolytic capacitors have a notched cross at the top and are flat there. If this surface is curved upwards, the electrolytic capacitor is defective.
    • When this top has burst open or liquid has leaked out of the electrolytic capacitor at the bottom, it is defective.
    • The liquid can also cause damage to the circuit board. In this case, the circuit board should be cleaned with isopropanol and any damaged lines must be repaired before installing a new electrolytic capacitor.
    • Now remove the circuit board. To do this, loosen all connections and remove the corresponding screws.
    • Next, the defective electrolytic capacitor must be desoldered (desoldering pump or desoldering wire help).
    • Now replace the defective electrolytic capacitor. The new electrolytic capacitor must have the same capacitance and voltage. The connection wires and height should also be the same.
    • Now reinsert the circuit board and make all connections again.
    • Then screw the cover back on.
결론
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
HRi
회원 가입일: 01/24/22
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 38
지난 30일: 215
전체 시간: 3,811
