주요 콘텐츠로 건너뛰기
Replace the Slider on a Plastic Tooth Zipper
필요한 것
동영상 개요
  1. Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 3/3
    • Locate the top of the zipper on the side with the slider.
    • Use end nippers to cut the stop off of the zipper.
    • Be careful to only cut the plastic, not the fabric.
  2. Replace the Slider on a Plastic Tooth Zipper: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove any remaining pieces of the stop from the garment.
  3. Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 3/3
    • Slide the slider off of the garment.
  4. Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 3/3
    • Insert the new slider onto the zipper.
    • You may need to tug a little to get the slider over the webbing from the old stop.
    • Make sure the zipper slider is oriented right-side up when you slide it back onto the zipper.
  5. Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 3/3
    • Grab a replacement stop.
    • Position the new stop over the webbing in the same place where the old stop was located.
  6. Replace the Slider on a Plastic Tooth Zipper: 6 단계, 이미지 1/2 Replace the Slider on a Plastic Tooth Zipper: 6 단계, 이미지 2/2
    • Use pliers to crimp the stop into place.
결론
For replacement parts or further assistance, contact Patagonia Customer Service.
다른 59명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,128 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 23개
Where do I get the parts needed?
jonaskrat - 답글
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - 답글
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - 답글
댓글 쓰기
조회 통계:
24 시간 전: 129
7일 전: 935
30일 전: 4,030
전체 시간: 731,528
