주요 콘텐츠로 건너뛰기
Replace the Slider on a Plastic Tooth Zipper
필요한 것
동영상 개요
  1. Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 1 단계, 이미지 3/3
    • Locate the top of the zipper on the side with the slider.
    • Use end nippers to cut the stop off of the zipper.
    • Be careful to only cut the plastic, not the fabric.
  2. Replace the Slider on a Plastic Tooth Zipper: 2 단계, 이미지 1/1
    • Use tweezers to remove any remaining pieces of the stop from the garment.
  3. Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 3 단계, 이미지 3/3
    • Slide the slider off of the garment.
  4. Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 4 단계, 이미지 3/3
    • Insert the new slider onto the zipper.
    • You may need to tug a little to get the slider over the webbing from the old stop.
    • Make sure the zipper slider is oriented right-side up when you slide it back onto the zipper.
    Bonjour, je n’arrive pas à faire descendre le nouveau curseur, seriez vous pourquoi ?
    vcarpentier78 - 답글
    Regardez s’il y a quelque obstruction le long de la fermeture, un bout de fil peut dérailler ou bloquer le curseur ou une dent qui est déformée. Un peu de lubricant pourrait aussi aider. Bonne chance.
    haingu nguyen -
  5. Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 1/3 Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 2/3 Replace the Slider on a Plastic Tooth Zipper: 5 단계, 이미지 3/3
    • Grab a replacement stop.
    • Position the new stop over the webbing in the same place where the old stop was located.
  6. Replace the Slider on a Plastic Tooth Zipper: 6 단계, 이미지 1/2 Replace the Slider on a Plastic Tooth Zipper: 6 단계, 이미지 2/2
    • Use pliers to crimp the stop into place.
    Incollato. Solo pressione o a caldo?
    Piergiorgio Fol - 답글
    Ciao @piergiorgiofol, da quanto ha capito le istruzioni della guida e il video sopra, bisogna solo premere il fermo sulla fettuccia con l'aiuto delle pinze. Non viene menzionato di scaldare. Forse dipende dal materiale della parte di ricambio che usi, ma l'etichetta o il packaging di questa dovrebbe indicare se c'è qualcosa di speciale a fare per montarla. Buona riparazione!
    Claire Miesch -
결론
For replacement parts or further assistance, contact Patagonia Customer Service.
다른 59명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
89,017 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 23개
Where do I get the parts needed?
jonaskrat - 답글
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - 답글
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - 답글
Where did you get the replacement end plastic endstop?
Deborah Spaulding -
I can not thank you enough for this tutorial. I had contacted a seamstress and she said it would have to be replaced. Thank heavens I found your site. The zipper pull has been replaced on the zipper and I'm awaiting my order of stops to replace the top stop. Thank you, Thank you!
Mary Axtell - 답글
Where can I buy the things needed to do this please?
Val Neale - 답글
Amazon or sailrite.com
Scott Lamorte -
Hi
The tutorial is fab and I checked out sailrite for zippers which brings me a step further, but how do I determine the right size zipper. There is no numbers or anything on my current broken zipper. I thought about measuring the bottom or the top and going from that measurement? Any feedback appreciated.
thanks Jenny
Jenny - 답글
Where did you get the replacement stop?
edward schmitt - 답글
I lost the original slider …. how will we know what to buy ?
Rishi Rampaul - 답글
I lost the original slider … how will I know what to buy ?
Rishi Rampaul - 답글
Sometimes, if the slider is not broken, but it doen’t connect the two sides any more, you can very, very gently squize the upper and lower side of the slider. Most of the times it will be o.k. again.
Paul A. - 답글
You can check other zippers (if any) on pockets as they’re often the same size. A good quality zipper will have the size stamped on the back. Standard exterior coat zippers are size 5.
Sarah Gerber - 답글
Thanks for keeping this tutorial up! I broke a tooth near the bottom stopper on a zipper and this helped me to fashion a fix!
Jamie Saulsbury - 답글
'''Plastic zipper on a comforter coverlet will not stay zipped… it splits on both sides of the zipper. There’s no # on bottom of slider(made in China I think!) so how do I fix it? It’s a small slider.. nothing actually seems to be wrong with the slider! The plastic zipper just won’t start… it gaps open every time you zip it! In front & in back of the slider!!
Marcia - 답글
How can I fix one with the slider (plastic teeth) when the stop is hidden (Sewn in) And I managed to get both sides feeding into the slider just fine but when I zip it, the zipper behind just pulls apart again. (This is on a Large sectional-sized throw pillow) so… it’s on track on both sides, the slider moves, but the zipper won’t stay zipped. It just pulls agape again. Help please
garnetthudnall - 답글
Thanks so much! Zipper fixed in a few minutes :) I just reused the stopper piece too :) Great presentation with excellent video quality =D Thank you ☺️
Lesley Pain - 답글
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
Marty Chapman - 답글
If your garments were made better the zippers wouldn't break so often. I've had three SST jackets and various zippers have failed on all three. Now I but Rapala Pro jackets - twice the jacket at half the price.
Garnet Brake - 답글
How do I replace jusy 1 tooth toward the middle?
Silky Jones - 답글
Thank You ! Very Helpful ! Yay!
PL Low - 답글
댓글 쓰기
조회 통계:
24 시간 전: 158
7일 전: 1,296
30일 전: 5,204
전체 시간: 717,493
