이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the top of the zipper on the side with the slider.
Use end nippers to cut the stop off of the zipper.
Use tweezers to remove any remaining pieces of the stop from the garment.
Grab a replacement stop.
Position the new stop over the webbing in the same place where the old stop was located.
다른 59명이 해당 안내서를 완성하였습니다.
댓글 23개
Off of another zipper
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
