주요 콘텐츠로 건너뛰기
Replace the thermal fuse on a GHD Classic V
필요한 것
  1. Replace the thermal fuse on a GHD Classic V, Thermal fuse: 1 단계, 이미지 2개 중 1개 Replace the thermal fuse on a GHD Classic V, Thermal fuse: 1 단계, 이미지 2개 중 2개
    • Before you begin, unplug your ghd hair straightener.
    • Remove the two plastic hinge covers located on each side of the ghd by using a thin and flat spudger.
    • The plastic hinge covers are attached via two clips. Be careful not to break the clips.
  2. Replace the thermal fuse on a GHD Classic V: 2 단계, 이미지 2개 중 1개 Replace the thermal fuse on a GHD Classic V: 2 단계, 이미지 2개 중 2개
    • Unscrew the right side hinge support.
    • Remove the centering tube.
    • If unscrewing proves difficult, try using a Philips screwdriver on both sides of the tube.
  3. Replace the thermal fuse on a GHD Classic V: 3 단계, 이미지 1개 중 1개
    • Unscrew both Philips screws to remove the cover.
    • The heat fuse is on the power button's side.
  4. Replace the thermal fuse on a GHD Classic V: 4 단계, 이미지 2개 중 1개 Replace the thermal fuse on a GHD Classic V: 4 단계, 이미지 2개 중 2개
    • Unscrew the 4 screws from the the plate and then remove it.
    • The outer screws corresponds to the "Fuse" fuse. The center screws corresponds to the ceramic plate fuse.
  5. Replace the thermal fuse on a GHD Classic V: 5 단계, 이미지 3개 중 1개 Replace the thermal fuse on a GHD Classic V: 5 단계, 이미지 3개 중 2개 Replace the thermal fuse on a GHD Classic V: 5 단계, 이미지 3개 중 3개
    • Slowly lift the fuse and cut the two cables with your wire cutter.
    • You can now remove the fuse from its compartment as well as the two cables by pulling on them towards the front.
  6. Replace the thermal fuse on a GHD Classic V: 6 단계, 이미지 3개 중 1개 Replace the thermal fuse on a GHD Classic V: 6 단계, 이미지 3개 중 2개 Replace the thermal fuse on a GHD Classic V: 6 단계, 이미지 3개 중 3개
    • Start by inserting your new fuse's cables and let about a centimeter of slack.
    • Insert the end of the fuse.
    • Pull on both cables outward to completely fit the fuse in its compartment.
  7. Replace the thermal fuse on a GHD Classic V: 7 단계, 이미지 1개 중 1개
    • Watch out: the two white cables are screwed in the center; the brown cables are screwed at the outer posts.
결론
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Caplou.com
회원 가입일: 03/24/21
193 평판
안내서 1개를 작성함
Caplou Caplou 회원
Business
1 회원
안내서 2개를 작성함
댓글 3개
Thanks for this! I am searching for a suitable fuse replacement, will this one work?
TB05-BB5D-145 (up to 160°C)
https://www.conrad.de/de/p/tb05-bb5d-145...
Francisco - 답글
Bonjour, non ce fusible thermique n'est pas compatible, la température de déclenchement n'est pas la bonne, de plus la taille de celui-ci est trop large et le branchement ne comporte pas les deux connecteurs.
Si vous avez besoin du modèle correct, veuillez nous contacter ici: https://caplou.com
Belle journée
L'équipe Caplou
Caplou.com -
Parfait merci beaucoup il re fonctionne !!!
sourya lasfar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 69
전체 시간: 9,540
