주요 콘텐츠로 건너뛰기
Replacement Ram
필요한 것
  1. Replacement Ram, Ram: 1 단계, 이미지 1/1
    • Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
  2. Replacement Ram: 2 단계, 이미지 1/1
    • After removing the screw, using your finger slowly lift out and remove the cover.
  3. Replacement Ram: 3 단계, 이미지 1/3 Replacement Ram: 3 단계, 이미지 2/3 Replacement Ram: 3 단계, 이미지 3/3
    • Lift the flap
    • Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
    • The ram is to be removed at a 45 degree angle.
  4. Replacement Ram: 4 단계, 이미지 1/1
    • Pull out cleanly and you have now successfully removed the ram.
결론
Eric Martinez
회원 가입일: 02/14/17
637 평판
안내서 6개 작성하였습니다
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 361
