필요한 것
다른 21명이 해당 안내서를 완성하였습니다.
댓글 9개
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
note8 siyah ekran bozuldu. fiyat nedir
Mine is coming up saying Note Network found after completion of the repair any ideas?
