주요 콘텐츠로 건너뛰기
    • Insérer un commentaire.
결승점
다른 21명이 해당 안내서를 완성하였습니다.
ian mdx
회원 가입일: 2016년 06월 30일
7,933 평판
안내서 17개 작성하였습니다
댓글 8개
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - 답글
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - 답글
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - 답글
Will the phone remain waterproof after this repair?
cj-dm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 51
전체 시간: 22,934
