필요한 것
다른 21명이 해당 안내서를 완성하였습니다.
댓글 9개
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
note8 siyah ekran bozuldu. fiyat nedir
Mine is coming up saying Note Network found after completion of the repair any ideas?
The phone will only remain waterproof if you re-apply the correct waterproof seal, and even then I wouldn’t trust it.
Is there a way to buy an OEM NOTE 8 front glass replacement instead of the Chinese crap on eBay?
Thanks
Just saw our question while preparing to change a Note 8 and I do not know if you received and answer. GadgetFix or Digital Supply USA(who also uses GadgetFix as a supplier) sell Samsung(original OEM) screens the cheapest so far.
Is that copper colored piece supposed to stay on the phone after removing glass and touch screen?
Bill Stark - 답글
