주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.
    1. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances., Compilation of thermal fuse values for water heaters, used in household appliances. THERMAL FUSE or THERMO FUSE.: 1 단계, 이미지 2개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances., Compilation of thermal fuse values for water heaters, used in household appliances. THERMAL FUSE or THERMO FUSE.: 1 단계, 이미지 2개 중 2개
      • This document is a summary of other documents I have already published regarding thermal fuse values for coffee machines. It is a work in progress, so as I gather more values, I will add them. Anyone who wishes can contribute values based on their knowledge or research. Together, we can create a useful database.
      • When replacing a thermal fuse, we must consider both the temperature it can withstand and the current it can handle.
      • NEVER INSTALL A THERMAL FUSE THAT WITHSTANDS LESS TEMPERATURE; always use one with the same or slightly higher rating.
      • NEVER INSTALL A THERMAL FUSE THAT WITHSTANDS LESS CURRENT, as it will overheat easily. Always use one with the same rating; if this parameter is higher, it's even better. The key factor of a thermal fuse is ITS MAXIMUM OPERATING TEMPERATURE.
      • For more information, search on Google: Thermal fuse.
      댓글 쓰기
    2. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 2 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 2 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 2 단계, 이미지 3개 중 3개
      • The Nescafé Dolce Gusto Krups KP1600 coffee machine has 3 thermal fuses, 2 in the boiler and 1 in the water pump.
      • Two thermal fuses located on the boiler, secured by a metal plate and screw, both have blown.
      • 133º - 10A
      • RELATED DOCUMENT, MORE EXTENSIVE: https://es.ifixit.com/Gu%C3%ADa/CAFETERA...
      댓글 쓰기
    3. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 3 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 3 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 3 단계, 이미지 3개 중 3개
      • Nescafé Dolce Gusto Krups KP1600 coffee machine water pump fuse.
      • Located in the body of the water pump, inserted, easy to extract. When the pump is installed, it is barely visible.
      • 113º - 10A
      • As an observation: This fuse rarely blows; the water pump winding is usually damaged first.
      댓글 쓰기
    4. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 4 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 4 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 4 단계, 이미지 3개 중 3개
      • Nespresso coffee machines, Delonghi, and many similar models.
      • 2 thermal fuses on the boiler, one on each side, secured by a metal plate and screw.
      • 167º - 5 A
      댓글 쓰기
    5. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 5 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 5 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 5 단계, 이미지 3개 중 3개
      • Saeco Via Veneto coffee machine: 1 thermal fuse located on the boiler at the top of the machine.
      • 186º - 5A. In the market, we can find a compatible one rated for 192º.
      • It is a common fault for this model: the machine is dead due to a blown thermal fuse. There are some videos on YouTube about it.
      댓글 쓰기
    6. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 6 단계, 이미지 1개 중 1개
      • NOTE: The replacement of thermal fuses is done with electrician-type terminal blocks, isolating the entire body (NOTE: in the photo, it is still pending isolation). The fuses are crimped at their connection to the wire. If they need to be soldered, there is a technique to prevent damage, by holding them with a wet cloth or an ice cube.
      댓글 쓰기
    7. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 7 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 7 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 7 단계, 이미지 3개 중 3개
      • Princess Hot Air Fryer: Thermal Fuse Value AUPO BF172 172º / 10 A / 250V - G1 is located on the metal plate of the heating element, requiring almost complete disassembly. It has 2 fuses enclosed in textile tubes, and usually, one of them blows. This causes the fryer to stop heating and the fan to stop rotating, although the display still turns on.
      • Repair guide: New contribution made 09/07/2023.
      댓글 쓰기
    8. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 8 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 8 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 8 단계, 이미지 3개 중 3개
      • Equation DL06 Stand Air Convector, dead, does not turn on.
      • Thermal fuse fault at 157º, replaced with one rated for 192º, slightly moving it away from the support using electrician terminal blocks.
      • Related repair guide
      댓글 쓰기
    9. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 9 단계, 이미지 1개 중 1개
      댓글 쓰기
    10. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 10 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 10 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 10 단계, 이미지 3개 중 3개
      댓글 쓰기
    11. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 11 단계, 이미지 3개 중 1개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 11 단계, 이미지 3개 중 2개 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 11 단계, 이미지 3개 중 3개
      • RIVER PA-4628-A griddle does not heat up or light the thermostat pilot light. 117ºC 16A THERMAL FUSE.
      • TO BE CONTINUED... WHEN I GATHER MORE DATA ON DEVICES WITH THERMAL FUSES, you can contribute to this document by sharing what you have been able to find out about other coffee makers and equipment.
      댓글 쓰기
    12. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 13 단계, 이미지 1개 중 1개
      댓글 쓰기
결론
Informative guide under construction
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Carlos López (España - Spain)
회원 가입일: 07/01/15
104,630 평판
안내서 383개를 작성함
9가이드 댓글
Hola!
No me parece adecuado sustituir los fusibles quemados por otros de más temperatura. El fabricante estableció una temperatura maxima de seguridad que no permita que se dañen otros componentes, si sustituimos por uno de mayor capacidad, permitirá que el dispositivo se caliente másy se puedan ocasionar daños irreversibles en otras piezas mas costosas o insustituibles. Por otra parte, cambiarlos por otros de menor temperatura de corte, hará que salten en regimen de uso normal.
Arduinoxino - 답글 공유
Hola, Respeto tu opinion, pero por experiencia en numerosas reparaciones, el fusible termico se puede colocar de un valor ligeramente mayor ya que realmente sigue cumpliendo su función, en los aparatos que lo cambiar si tienen sobretemperatura se funde igualmente.
Carlos López (España - Spain) - 답글 공유
¿Puedo cambiar un fusible 172 por uno 192 en una free air?
Fernando Bravo - 답글 공유
Si, realmente son 20 º de diferencia a esa temperatura elevada la proteccion seguira siendo la misma
Please tell me how to dissasemble the same model Nespresso/Delonghi coffee maker as you show in your pictures. Or maybe you have a PDSF of the repair manual you could post here. I can not find any instructions or videos showing the removal of the outside panels for that model. It has rivets not screws on the bottom and elsewhere. I need to know if the side panels have plastic clips holding them or those rivets. Also, can you verify this model has a thermal fuse for the pump? Mine starts and lights up correctly when you push the power button, it gets hot but then the pump doesn't start when you push the coffee button. I believe I know how I accidentally overheated it yesterday causing the pump thermalfuse to blow..
Michele Duval - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 116
지난 30일: 460
전체 시간: 10,574
