주요 콘텐츠로 건너뛰기
Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690
필요한 것
  1. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690, Graphics processing unit in a HP Pavilion 690.: 1 단계, 이미지 1/1
    • Power off the desktop and unplug the power cable.
    • Hold power button for 5 seconds to discharge the capacitors.
    • Remove the side panel from the computer.
  2. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 2 단계, 이미지 1/1
    • Remove screws and place screws in bowl for safe storage.
    • Place the screws in a small bowl or on a magnetic mat so they don't get lost.
  3. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 3 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 3 단계, 이미지 2/2
    • Disconnect CD-ROM drive from the computer.
    • Caution: Ensure that you are properly grounded before touching any electrical components. Computer equipment is highly susceptible to damage through electric shock.
  4. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 4 단계, 이미지 1/1
    • Press in the small black lever on the back of the CD-ROM drive.
  5. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 5 단계, 이미지 1/1
    • Remove the CD-ROM drive from the computer.
  6. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 6 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 6 단계, 이미지 2/2
    • Disconnect the wires connecting the storage housing to the motherboard.
  7. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 7 단계, 이미지 1/1
    • Remove the storage housing from the computer.
  8. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 8 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 8 단계, 이미지 2/2
    • Unscrew the screws on the latch on the back of the computer.
  9. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 9 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 9 단계, 이미지 2/2
    • Flip the open the latch on the back of the computer.
  10. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 10 단계, 이미지 1/1
    • Disconnect the power cable from the GPU.
  11. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 11 단계, 이미지 1/1
    • Press down on the small lever at the base of the GPU to release the component.
    • Caution: When reassembling do not press this lever. It can lead to an improperly seated GPU and may damage the slot or the GPU.
  12. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 12 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 12 단계, 이미지 2/2
    • Pull the GPU gently out of the computer.
  13. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 13 단계, 이미지 1/2 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 13 단계, 이미지 2/2
    • Slide the replacement GPU into the slot.
  14. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 14 단계, 이미지 1/1
    • Plug the power cable into the replacement GPU.
결론
Yousif Al hamadani
회원 가입일: 10/06/22
229 평판
안내서 1개 작성함
University of North Texas, Team 2-2, Raign Fall 2022 University of North Texas, Team 2-2, Raign Fall 2022 회원
UNT-RAIGN-F22S2G2
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 24
전체 시간: 427
