소개
You need to disconnect or replace the fans on your Dell XPS 13 9380, this guide is for you!
필요한 것
Use a Torx T5 driver to unscrew the eight screws securing the back panel.
Use a spudger to pry up and loosen the back panel.
Lift the back panel up slightly from the non-hinged edge.
Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
When the back panel clips are free, remove the back panel.
Disconnect the cable from the battery by pulling the connector towards the battery.
Remove the four screws (M2 x 2) securing the battery.
Remove the screw (M1.6 x 4) securing the battery.
Remove the battery from its recess.
1- Remove the screw (M1.6 x 3) that fixes the WiFi card and the cable holder the webcam on the motherboard.
2- Remove the WiFi card and the cable holder for the webcam from the motherboard.
3- Disconnect and lift the webcam cable from the motherboard. You will need to remove the adhesive tape that attaches the cable.
4- Disconnect the power cable from the right fan of the motherboard.
5- Disconnect the power cable from the left fan of the motherboard.
6- Remove the two screws (M1.6 x 3) that attach the fans to the motherboard.
7- Remove the fans from the motherboard.
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Schwarzer님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
I do apologise if this is a redundant question. Would the bits included with the IFIXIT Essential Toolkit be sufficient to proceed with this operation, or is a more extensive kit like the Mako used here be a necessity? Thanks for the help!
