소개
You must disconnect or replace the coin cell battery in your Dell XPS 13 9380, this guide is for you!
필요한 것
Use a Torx T5 driver to unscrew the eight screws securing the back panel.
Use a spudger to pry up and loosen the back panel.
Lift the back panel up slightly from the non-hinged edge.
Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
When the back panel clips are free, remove the back panel.
Disconnect the cable from the battery by pulling the connector towards the battery.
Remove the four screws (M2 x 2) securing the battery.
Remove the screw (M1.6 x 4) securing the battery.
Remove the battery from its recess.
1- Disconnect the coin cell battery cable from the motherboard
2- Use a lever to remove the coin cell battery from the motherboard.
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Schwarzer님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
Note to anyone replacing this, the model is a ML-1220 3V rechargeable coin cell battery, you will need one with a Dell compatible connector or to solder said connector to battery that comes with preinstalled solder tabs.
StereoTypo - 답글
