주요 콘텐츠로 건너뛰기
Replacement of the motherboard on a Dell XPS 12 9Q23
필요한 것
  1. Replacement of the motherboard on a Dell XPS 12 9Q23, Battery: 1 단계, 이미지 1/1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Replacement of the motherboard on a Dell XPS 12 9Q23: 2 단계, 이미지 1/1
    • Carefully remove back panel after all screws have been removed.
  3. Replacement of the motherboard on a Dell XPS 12 9Q23: 3 단계, 이미지 1/1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Replacement of the motherboard on a Dell XPS 12 9Q23: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the battery: 5 단계, 이미지 1/1
    • Once all the screws have been removed the battery is now safe to extract
  6. Replacement of the motherboard on a Dell XPS 12 9Q23, Cooling Fan: 6 단계, 이미지 1/1
    • Caution: Ensure your laptop has been powered down.
    • Close the laptop, flip the laptop over, and pop off the back small panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
  7. Replacement of the motherboard on a Dell XPS 12 9Q23: 7 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the screws along the edge of the bottom cover.
    • Use a magnetic board if possible to keep track of screws.
    • Open the center cover and use a Phillips #00 screwdriver to remove single screw.
  8. Replacement of the motherboard on a Dell XPS 12 9Q23: 8 단계, 이미지 1/1
    • Carefully remove the back cover.
  9. Replacement of the motherboard on a Dell XPS 12 9Q23: 9 단계, 이미지 1/1
    • Caution: Be mindful of static electric charge across the battery port. Usage of an antistatic strap is recommended but not required.
    • Disconnect the battery to prevent electrical shock.
    • If battery replacement is desired then the battery may be removed at this point via removal of the battery's perimeter screws.
  10. Replacement of the motherboard on a Dell XPS 12 9Q23: 10 단계, 이미지 1/1
    • Disconnect yellow-colored ribbon cable from its port which sits at the bottom left of the fan housing.
  11. Replacement of the motherboard on a Dell XPS 12 9Q23: 11 단계, 이미지 1/1
    • Dislodge the CMOS battery.
    • Unplug CMOS cable.
    • This step is not completely necessary, it allows extra room to maneuver the fan in and out during replacement.
  12. Replacement of the motherboard on a Dell XPS 12 9Q23: 12 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to loosen the screws that secure the heat sink's heat spreader.
    • Screws cannot be fully removed from heatsink.
  13. Replacement of the motherboard on a Dell XPS 12 9Q23: 13 단계, 이미지 1/1
    • Grip the heat sink from the sides and carefully lift it up to remove it.
    • Heatsink is a device used for absorbing heat and necessary to remove to reach the fan.
    • At this time there will be a whitish powder between the heatsink and the CPU. This powder below the heat spreader is degraded thermal paste. DO NOT wipe away this powder unless the thermal paste will be replaced upon reassembly.
  14. Replacement of the motherboard on a Dell XPS 12 9Q23: 14 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the two cooling fan screws.
  15. Replacement of the motherboard on a Dell XPS 12 9Q23: 15 단계, 이미지 1/1
    • Unplug the fan cable.
  16. Replacement of the motherboard on a Dell XPS 12 9Q23: 16 단계, 이미지 1/1
    • The cooling fan can now be removed and a new one can be installed.
  17. Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the WiFi card: 17 단계, 이미지 1/3 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the WiFi card: 17 단계, 이미지 2/3 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the WiFi card: 17 단계, 이미지 3/3
    • We removed the battery to avoid electric shocks.
    • Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
    • Remove the screw with a #00 Phillips screwdriver.
    • Now remove your WiFi card to replace it.
  18. Replacement of the motherboard on a Dell XPS 12 9Q23, Adhesive tape: 18 단계, 이미지 1/1
    • Remove the adhesive tape.
  19. Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the hard disk drive: 19 단계, 이미지 1/2 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the hard disk drive: 19 단계, 이미지 2/2
    • Remove the hard disk from its location.
  20. Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the operating button: 20 단계, 이미지 1/2 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the operating button: 20 단계, 이미지 2/2
    • We removed the battery to avoid electric shocks. The hard disk, WiFi card and fan have also been removed.
    • Remove the connector with a pair of pliers or your fingernail.
    • Remove the screws with a #00 Phillips screwdriver.
    • Remove the card afterwards.
  21. Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the motherboard: 21 단계, 이미지 1/3 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the motherboard: 21 단계, 이미지 2/3 Replacement of the motherboard on a Dell XPS 12 9Q23, Remove the motherboard: 21 단계, 이미지 3/3
    • Disconnect the various connections from the motherboard.
    • Carefully turn the motherboard over to disconnect the tablecloth from the keyboard.
    • You can now replace the motherboard.
결론
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Schwarzer님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Schwarzer
회원 가입일: 08/07/19
4,689 평판
안내서 13개 작성하였습니다
i.Fixit FR Team i.Fixit FR Team 회원
Community
3 회원들
안내서 40개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 756
