주요 콘텐츠로 건너뛰기
Replacing Antenna on Realistic Weatheradio
필요한 것
  1. Replacing Antenna on Realistic Weatheradio, Antenna: 1 단계, 이미지 1/1
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: 2 단계, 이미지 1/1
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: 3 단계, 이미지 1/2 Replacing Antenna on Realistic Weatheradio: 3 단계, 이미지 2/2
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
결론
After following these steps, the Realistic Weatheradio should be able to work and function normally.
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
Matthew
회원 가입일: 07/17/15
136 평판
안내서 1개 작성함
Texas Tech, Team 3-5, Rauch SU 2015 Texas Tech, Team 3-5, Rauch SU 2015 회원
TTU-RAUCH-SU15S3G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 883
