주요 콘텐츠로 건너뛰기
Replacing Atari Lynx Buttons and D-Pad
필요한 것
  1. Replacing Atari Lynx Buttons and D-Pad, Atari Lynx: 1 단계, 이미지 1/1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Buttons and D-Pad: 2 단계, 이미지 1/1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Buttons and D-Pad: 3 단계, 이미지 1/1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Buttons and D-Pad: 4 단계, 이미지 1/1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Buttons and D-Pad, Buttons and D-Pad: 5 단계, 이미지 1/1
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from the front panel of Atari.
  6. Replacing Atari Lynx Buttons and D-Pad: 6 단계, 이미지 1/2 Replacing Atari Lynx Buttons and D-Pad: 6 단계, 이미지 2/2
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
결론
Tyler Williams
회원 가입일: 01/26/14
333 평판
안내서 2개 작성하였습니다
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 회원
CPSU-MANESS-W14S1G42
5 회원들
안내서 16개 작성하였습니다
댓글 한 개
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 2,193
