소개
This guide will show you how to replace the speaker from your Atari Lynx. Before beginning, it is a must to know how to solder and desolder. In order to find out how to do these processes there will be a link in the the following steps. Aside from soldering, most steps should be easy to follow and simple.
부품
부품은 필요하지 않습니다.
  1. Before disassembling your Atari Lynx, be sure the device is powered off.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  5. Remove the control panel by pinching the sides with your fingers and lifting  it away from the Atari.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  6. Remove the logic board from the console. Flip the logic board so the screen is facing down.
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  7. Now you will need to desolder both of the wires connected to the speaker. If you are having trouble desoldering, click here.
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Williams
회원 가입일: 2014년 01월 26일
317 평판
안내서 2개 작성하였습니다
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 회원
CPSU-MANESS-W14S1G42
5 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 790
